1 - 20 of 24 Posts
My 2005 Wee is still being shipped to me but I'm wondering where I'll store it. Can someone measure their bike and tell me the length and width the bike takes up on the side stand. My bike does not have side bags.
I think on the side stand the bikes sits pretty close to vertical. Is that right or does it lean a bit and take up more width?
I tend to keep mine on the center stand as well. I keep mine here at work (it is good to be the boss sometimes) and I worry about someone knocking it over on themselves or something while messing with it. Shouldn't happen but you never know. At times we also have employees kids around too. Them climbing up on a bike on the center stand seems less likely to fall over on them...not that they should be on my bike.
BTW I have a 05 Wee (Red) and love it....
I keep mine in the basement .However , I'm not allowed to run it in the basement .
Alex
"not allowed"?! those Canadian women keep you guys scared, don't they? MAN UP!!
It doesn't have a center stand yet. I will be adding one of those before too long.
Be careful keeping your bike in the basement my uncle has a 1968 triumph that's been in his basement since 1982.
If you can park the right side of the bike next to a wall and aren't worried about it tipping over, you can put a 1/2" or so piece of wood under the kickstand to get it more upright. You can save several inches of space that way.
A bike is more stable on a side stand than it is on a center stand, just make sure to leave it in gear on the side stand. The side stand creates a 3 point contact area, whereas the center stand only has 2.
Mine has 3 points of contact when on the center stand. Let me know if you figure out how to balance anything on two points of contact! :confused:
Two points defined a line. Three define a plane. You get the idea ....
I like your helmet boxes!
No, but Philstrom kinda gave me the skinny~
I use a section of 2x8 on its side (1.5 inches under the kickstand) which stands up the bike almost vertical but still leaning enough to keep it stable. This is also a good position for lifting the bike onto a rear stand (I don't have a centerstand). This allows me to fit the bike in the garage next to my car but it does block the rear door from opening.
1 - 20 of 24 Posts
