1 - 2 of 2 Posts
Say are the fuel pumps from the new bikes backwards compatible with the early model bikes?
I need to swap out my fuel pump on my 02.
Thanks in advance,
-DA
There are two types of fuel pumps. One is on 2007 and later 650s. The other is everything else. Are you sure you need a new fuel pump? You may just have a clogged high pressure fuel filter. That is the most common fuel pump problem. See the pinned threads at http://www.vstrom.info/Smf/index.php/board,15.0.html
1 - 2 of 2 Posts
