Have just finished installing the extended lines to do the TBS, put everything back together and started the bike. All looked OK till a puddle started to form at the front of the skid plate and then the smell of fuel
Turned it of and started to have a look around to see if I could locate the problem. Could see some fuel running down the front sproket cover. Checked the conection of the fuel line to the tank, dry. Started the bike back up and the leak was coming from between the throttle bodies and running down the clutch hose. Remove tank and aircleaner and noticed the main fuel line that conects to the throttle bodies was wet.
Are the O rings in these replacable? Suzuki tells me no the whole line needs replacing at $72.:jawdrop: Can I replace with high pressure line and clamps?
Cheers Hugh
Cheers Hugh
