Hi all,
So in the last couple weeks, maybe the last two or three fill-ups of gasoline, I've noticed the fuel level no longer illuminates the top bar. The last time I filled up I paid closer attention and it showed full when I rode away from the pump but then after a couple miles it dropped again. I made sure the last couple times I had the tank full to the bottom of the filler neck, if that is the right terminology (about one inch from the top outer surface of the fuel tank). I guess the LED could be going out.
I checked for leaks and there were none. Also checking the MPG it seems normal.
Mine is a 2006 USA DL1000.
Thanks in advance for any tips or advice.
-Bob
-Bob
