Hello - So my '11 Wee is having its first issue -
Has anyone her experienced any similar issues?
I am having an problems with my fuel gauge and/or sending unit. At just under 2k miles now, my fuel gauge has become highly inaccurate. In the last 2 tanks the first bar did NOT go off until I had less than 1 gal. This has become progressively worse over the past 4 tanks or so...
The first time I noticed something was not right was when I filled up at one
point and it took way less than expected - the indicator was showing less fuel than actually available. No so bad, the opposite of what happening now.
Then it went the other way - now I fill up by miles as I cannot trust the gauge - fueling appx 4.5 gal into it when it still has 4 bars. Very inaccurate - not that I expect precision, but I do expect some feeling of real measurement. I have never had this issue before after many bikes, new and used over the years.
So I took it to the dealer. They saw the issue - they called Suzuki, and they
are making the dealer jump through testing hoops: empty tank, measure Ohms, put it 1 gal, measure Ohms, more fuel, take fuel out... Measure, test this and that - you get the picture. All this though its visibly obvious that the gauge says full and the tank is almost empty. Now I need to take it in again for yet another follow up. And then IF they agree something is not right, they will order a part... for another visit.
Suzuki's first response is that "...fuel gauges are not meant to keep accurate
fuel usage.." For real - its about 60% inaccurate.
What does Suzuki consider acceptable on this issue? Who knows - they are OK with an error margin of 10 to 12% on the speedo. So at 25k miles, my bike will read ~27k +/- miles. At least there is no mileage on the warranty.
As to the fuel, my bet is that's the sending unit - but the dealer shop manager is thinking it could be the instrument cluster. To this he says "... if I
order that and it does not correct the issue, you will have to pay for it
because I cannot return it to Suzuki..."
Unfortunately there are very few Suz dealers in area, and the closest one is
this one where I bough it - and its ~35 mi. The others are more than 1hr away.
So its not like I can be going to other (conveniently) for opinions or better
service.
I am becoming very disappointed in Suzuki - not stand-up in customer service - so far.
Jaime
sunnyorlando
service.
Jaime
sunnyorlando
