1 - 2 of 2 Posts
RE: 2005 DL 650
I'm confused. Several sources on this forum claim the flow rate should be 1,200 ml after 30 seconds. That's the same spec as for my DL 1000, so it sounds reasonable considering the systems are relatively similar. However, a paper manual titled DL650 A; K-4 thru K-8 calls for 168 ml after 10 seconds, which doesn't make sense to me since that's only 504 ml after 30 seconds. I don't have the pressure gauge, but I want to test the pump and filter, and this method seems like a practical alternative. But, what's the proper flow rate?
1 - 2 of 2 Posts
