Strom Trooper banner
41 - 49 of 49 Posts
Have you perhaps read any of these threads, https://www.stromtrooper.com/dl1000-2002-2012/425307-2007-vee-injector-spray-pattern.html or https://www.stromtrooper.com/dl1000-2002-2012/426613-k2-injectors-can-use-yamaha-marine-injector-rebuild-kit.html. The latter is for the Vee, but it would apply to the Wee as well. 'm not suggesting that the injectors part numbers are the same for both models, but the sourcing of spares / components is worth keeping in mind.
This site has some info on injectors and spray patterns, https://www.witchhunter.com/spraypattern1.php.
Discussion Starter #42
Both of my injectors work according to my multimeter. Only off thing is the o-ring on one of them is dead, and that is the one that was on the non-firing cylinder. Also apparently they have little filters in them, and those are definitely the originals. So I ordered a repair kit for the injectors. It should be here sometime this week.
Discussion Starter #43
Okay! Fuel is finally being delivered! After dealing with parts lost in the mail, defective filters, and unscrupulous eBay vendors...I was finally able to get the pump assembly sorted!
But, the rear cylinder still does not fire, of course. I know fuel is reaching the rear cylinder, because the spark plug was wet. It is however, quite black. Can I clean or should I just replace? Previously, I checked the rear cylinder's ignition coil resistance. It passed. I can not test the the peak voltage right now, not sure how without specialty tools.
So what should I do first to test that the spark plug is getting a spark?
Remove the spark plug. Push the spark plug cap back on it. Place the threaded/base area of the spark plug against a good ground. Crank engine. Watch for spark at plug.
Some like to install an old spark plug in the open hole. Or not. But be sure to blow debris out of the area. Some like to hold the spark plug by hand against a ground. That can be entertaining to anyone watching sometimes.
Discussion Starter #45
Oh, I've done that before. This time I'll wear gloves. :D
Discussion Starter #46
Checked the spark plug, it sparks, but it was pretty fouled. Hopefully from all the troubleshooting I have been doing. I have flooded the engine a few times.
So I cleaned the spark plug and the rear cylinder fires! I checked the headers on both with a spray bottle and they are both burning gas. But... it idles at about 4K RPM. I know I changed the idle screw when I was troubleshooting a while ago. So I reduced that guy down quite a bit and no change in engine speed.
Discussion Starter #47
Also, the black connector on the right side of the airbox was disconnected, and it was running at a much more acceptable RPM. Maybe 1100 I think. When I stopped and attached the black connector it went back to 4000 RPMs.
Discussion Starter #48
Adjusted the idle screw, no change whatsoever in engine speed. Could there be more air getting in somehow?
Discussion Starter #49
It runs!!!
One of the fuel injector's rubber seats was off, so the injector was leaking air into the cylinder. I redid all that and adjusted the idle screw and...the bike runs!!
Now on to the next three things...lol
(coolant, oil, bolt torque check, misc. routine maintenance)
Thank you everybody! You have all been a great help.
41 - 49 of 49 Posts
