Front Wheel Removal
4027 Views 34 Replies 11 Participants Last post by  Rolex
I have to replace the fork seals on my 2013 Wee, and going over my service manual for instructions I see I need a 12mm hex bit to pull the front axle. I bought a set of larger bits, but the 12mm is too big and the 11 is too small. I'm not sure if I got a poorly manufactured set of bits or if the correct size is an SAE bit. Can someone tell me what the correct size is? If it really is 12mm, I'll assume I got a bad set and try a different brand.
1 - 20 of 35 Posts
Probably; I got a set from Icon (Harbor Freight) and the 12mm hex fits like a glove; but your tool bag has a tool special for removing the front axle; is that long bar; with hex shaped ends
Hand Tool Finger Font Test tube
See less See more
Reactions: 4
I never even thought to check the factory tool kit. Oops. I'll take a look at that next time I'm in the garage before I go shopping again.
Reactions: 1
It should be 12mm, you can test this by putting a 12mm hex head of a bolt in the axel, it should be a good tight fit.
If you don't have a bolt get your 12mm spanner out and search your bike, there will be one somewhere you can remove to try.
Reactions: 2
It is supposed to allow you to make most of the regular maintenance with it (oil changes; remove fairings; unmount wheels and adjust chain slack and so.
That's a clever idea, thanks.
12mm, here's what I use:
Don't forget to remove the ABS sensor before trying to remove the wheel. I never forget that, except for last time :)
I'm doing the same project replacing a fork seal right now. The 6mm on the bottom is a bear. It's recessed so you need a long bit. I couldn't get mine with a t-handle and I was starting to muck it up trying. Those hex heads want to round off to easily. I'm gonna hit mine with an impact wrench:
Like a rookie, I forgot to loosen the top cap before removing the fork. Getting leverage with it removed is also a bear. But, once again: impact wrench to the rescue :)
See less See more
Reactions: 3
No hex wrench?
Like Rolex said grab a 12mm head bolt. Put three nuts on it with red loctite. Put the bolt head in the hex hole and your wrench on the nut closest to the bolt head.
Reactions: 4
Funny they don't tell you what all the OEM tools are for in the operator manual. :rolleyes:
  • Haha
Reactions: 1
two things, but from a guy been wrenching bikes 50 plus years. Pull front wheel. Break loose fork caps, break loose fork dampener before you ever loosen fork leg. I am blessed with a well equipped shop, a 3/8 impact will usually pop the dampener Allens loose with no trouble. Don't know how hard to loosen without impact. If you are close to Western KY I can give you tips and shop time for a six pack :)
Reactions: 1
Thanks @westkyguy . There's about 600 miles and an international border between me and Kentucky, but I appreciate the generosity of your offer anyway. I found a link on this site to a pretty detailed guide to this job, I'm planning to use that to tackle this job in the morning. Your advice and the guide I found match, so that gives me much more confidence. If anyone is interested, the link is:
The only thing I'm still worried about is how to figure out how long my spacers should be. I've read that the total length of the springs and spacers should be a bit shorter with the stiffer springs, but I haven't found any formula to figure out how much shorter.
About my original question here, the 12mm head on the bolt right under the front axle fits perfectly in the 12mm hex head for the axle, so it's definitely the tool I bought that's poorly manufactured. Annoyingly, the tool in my OEM kit is also the wrong size, or perhaps not the original tool. My kit is missing a few pieces compared to pictures I've seen on the site of other's. I've borrowed a better hex bit from a mechanic friend, it fits.
See less See more
Reactions: 1
Of course, the spacer length formula was on this site too, in a post from @RichDesmond in this thread:
I think I'm ready to get to work now.
Reactions: 1
How are you going to seat the new seal? That link you shared showing the guy using a wedge of wood. Not sure I love that. For my other bike I bought a special tool to seat it, but of course it's the wrong size for these forks and they're like $50. Don't want to spend the money.
I think I'm going to try the electrical tape trick, not done it before:
I have a replacement bottom bolt coming next week, I'm going to finish the job then. I think I mucked up the hex head in it enough I don't want to reuse it.
Reactions: 1
Not quite sure, but will probably follow whatever advice my mechanic buddy gives on it. I'll let you know how we do it. Didn't get to work on the bike today, the 'honey do' list got in the way.
Reactions: 1
I've done the tape trick. Works fine. You can also make a driver out of the appropriate sized PVC pipe. There are a bunch of UTube vids on how to do it.
Reactions: 5
There is no way in hell I would use the tape method.
Every time the tape hits the seal it is going to turn the seal InsideOut.
That seal will have one or two springs in it to keep the lip tight, if either spring is damaged or dislodged two things will happen,
The seal will not work as well as it should, not a big problem
If the spring becomes dislodged and starts floating around this can be a problem.
The top or outer spring will float around between the oil seal and the dust seal.
The lower inner spring will float between the oil seal and the fork tube bush.
Either of these situations could lead to the spring scraping the inner tube and hacking into the tubes chrome.
I use PVC pipe, here's a few tips,
it should be longer than the fork tube, that way you can put a block on the top and get a good straight hit on it no matter the type of fork being worked on
I use a grinder and split the end of the pipe 4 times, I use quite a thick blade so it removes quite a bit of material, I put a hose clamp around the end so I can squash/adjust the size of the end so it fits the seal perfectly, this avoids damage to the seal and the seal springs.
See less See more
Reactions: 1
I used the tape method. Sorry @Rolex, it was done before you posted your advice. First fork (right side) went back together in a few minutes following the instructions from the link I put above. Beautiful. Took the second fork apart, but can't get the damper rod bolt to thread in when I'm putting it back together. I've checked the threads on both the rod and the bolt, there is no problem there. If I pull the damper rod out I can thread the bolt in with no discernible resistance. Put the fork together and it won't catch. It almost seems like the bolt isn't reaching the damper rod. Going to search the forum some more to see if I'm missing something obvious then try again after work tomorrow.
The tape method works. I've done it and it works just fine
How do you know the inner spring is still in place and it has not been dislodged ????
You won't know until next time the forks are apart.
1 - 20 of 35 Posts
