1 - 11 of 11 Posts
Anyone have the tool for removing your front wheel, 19mm hex or special tool? Is it necessary?
The DL1000 is 19mm and the 650 needs a 12mm. Some folks use a bolt of the proper head size and a couple of jam nuts.
A
The crap steel in the toolkit will not deal with it. I too recommend the bolt and jamnut methods.
K
A 5/8" spark plug socket just happens to have a hex on the top side close to 19mm. On some of them you can insert an extension backwards through the socket and use it as an axel key. This tip saved my butt in the middle of nowhere.
Thanks guys, I checked my tool kit it doesn't seem to have anything to remove the front wheel, whats up with that, I guess my tire is supposed to last forever. I made one out of a bolt with a 19 mm head.
Rear wheel Removal tool
This forum just answered 1/2 of my doubt... now; can anyone tell me the size for the rear wheel tool for the Vee 1000? 8)
Re: Rear wheel Removal tool
you'll need a 24mm key..
J
your toolkit will have a 24mm wrench and an extension handle. that's what i use.
1 - 11 of 11 Posts
