I see that the 2004 through 2006 front wheel part numbers for the DL650 are the same, but change thereafter, even for the non-ABS model. Anybody know if the non-ABS wheels part number change in 2007 was superficial (e.g. color change or some such) and the wheel will actually fit a 2004 DL650? Do any other Suzuki bikes have the same PN# or a wheel that would fit the earlier DL650?
In 2007, the hubs got a larger diameter for both ABS and non ABS.
Discussion Starter · #3 ·
I take it the axle diameter and spacers are different too, or will the wheel with rotors from a non-ABS fit in the 2004 forks/calipers?
The axle diameter is the same and the spacers may be. The calipers are different as are the rotors.
Discussion Starter · #5 ·
Thanks, I suppose I'll have to stick with finding a 2004-2006 wheel unless I can cobble something else together (I'm looking to have a spare wheel with a TK 80 mounted to swap in when I ride with my KLR/KTM buddies)
