They are Mitsubishi Ultra Compact connectors. Mitsu UC is one source. Do a headlight relay kit too for more light and to preserve switch contacts and wiring connectors if you don't already have it. There is a minimum $20 order from EB.
Does anybody know what type of connector is used on the front turn signals, ie, Molex #xxxxx, or JAE Standard yyyyy?
I'll need to fit these to aftermarket signals and I don't want to cut them off the existing signals.
TIA,
Glenn
They do, indeed. Per Greywolf's comment, I'll be putting together an order for a bunch of stuff.Have you checked with Eastern Beaver?
Go here;
Suzuki VStrom Electrics
They may have exactly what you need..
Interesting site. Thanks for the link. I can see I'm going to spend a lot of time there.You might also want to look at DMP Marker Light Connectors. No need to cut your existing wiring.
Surfside Moto: DMP Marker Light OEM Connectors for Suzuki
