I would think that you would be able to use a drift and tap the washer either back or forwards so that the spines are aligned once again. Tight area, probably going to be slow-going, but I would try that.
Exactly. I used to own a 2017 and changed sprockets once. If I interpret the picture correctly, the washer was chewed up in the center because it rotated with the nut instead of being properly bent back flat first. Just take a large screwdriver against the sprocket on the outside of the washer and pop it out. It’s just sitting in there and the only reason it’s not just falling out is because the teeth are now wedged on top of the drive shaft teeth. But shouldn’t be hard to wedge it out towards you. No need to rotate it, I think. Next time flatten the washer first before removing the sprocket nut.@LunarFirefly
BTW - that washer typically doesn’t spin. The washer should have had 1 or 2 sections that were bent 90 degrees against one of the flats around the nut. That way it prevents the nut from spinning. You need to flatten the bent washer tab first. Did you miss that detail when removing the nut?
Either way, the new washer should be installed with the washer bent up against a flat on the nut, after torquing the nut down tight.
That is it's sole purpose in life, to not spin.BTW - that washer typically doesn’t spin.
I've just realised that is probably why it is such a mess and jammed into the splines. I'd never seen that before as I always flatten the washer before removing the nut.@LunarFirefly
@LunarFirefly
Yeah this was my first time removing the front sprocket. I thought I had flattened it enough but maybe not?Exactly. I used to own a 2017 and changed sprockets once. If I interpret the picture correctly, the washer was chewed up in the center because it rotated with the nut instead of being properly bent back flat first. Just take a large screwdriver against the sprocket on the outside of the washer and pop it out. It’s just sitting in there and the only reason it’s not just falling out is because the teeth are now wedged on top of the drive shaft teeth. But shouldn’t be hard to wedge it out towards you. No need to rotate it, I think. Next time flatten the washer first before removing the sprocket nut.
And thanks to your situation, I've gained a little "experience". The main reason I read most of these types of threads is figuring before long I'll be having to do this or that maintenance. Glad you got it worked out..............
But regardless. I now have experience with doing this and have learned a lot.
Hmmm, I kinda think the opposite. I'd rather the quick pop of the impact vs a long slow pull of a breaker bar. Impact is all I have ever used on 'em. Either way, all that torque on the internals make me cringe.In the future, don’t use an impact wrench on the counter-sprocket unless it’s the last resort. Use a socket and a long breaker bar. It’s easier on the internal transmission parts.
Follow @Brockie advice above and safe riding.
