1 - 6 of 6 Posts
Can someone please tell me the diameter of the front caliper pistons for the 2014+ 1000? I'm guessing they'd be listed in the service manual.
In the service manual there is no mention of the caliper piston diameters. Only torque specs and lubricants. Sorry.
Sent from my Moto Z (2) using Tapatalk
Which doesnt mean a whole lot to me...
When I see two different measurements for caliper pistons, I've always assumed the outside pair is a different size than the inside pair. I could be wrong.
And, do you happen know the size of the master cylinder bore? I believe it's stamped on the side. Would it be 14mm? 5/8"?
Thanks!!
Brock, master cylinder bore diameter is shown as 14mm(.55"). Each front caliper has 2 different sized pistons. The larger of the 2 measures approx 32.1mm(1.26"), the smaller measures approx 30.3mm(1.19").
The rear caliper's single piston measures approx 38.2mm(1.50").
As per my Suzuki '14 DL1000A Service Manual
1 - 6 of 6 Posts
