With hydraulic brakes there should be no "slack" As soon as the lever is squeezed the plunger on the master cylinder is actuated putting pressure in increasing amounts (as you pull the lever more) against the backside of the caliper pucks pushing outwards forcing the brake pads against the disc.
Cable actuated brakes could have "slack" in than as they went out of adjustment or the brake cable stretched.
I'm guessing either air still trapped or the master cylinder is going tits up.
