1 - 3 of 3 Posts
I need some help. I just changed my front shock, took of tire ect. While putting the brake calipers back on, the left one does not open all the way. when I turn the tire you can hear the brake pads rubbing. I pulled the brake lever a bunch of times no change. I did not do anything to the brake except pry it open with a screwdriver to put it back on. What is going on?
Do the brakes work OK? Most disc brakes will make a slight rubbing sound, if you have worked on them it will be worse until they bed back in. Have you test ridden? Some calipers require the pistons to be "screwed" back in to the caliper body, buy don't think that applies to the V. Hope you suss it out:D
1 - 3 of 3 Posts
