1 - 4 of 4 Posts
I proactively replaced my 2 front wheel bearings at 37K miles. Following the forum advice, I froze the bearings overnight, carefully tapped out the old bearings with a drift, cleaned the hub well, heated the hub with a propane torch, and carefully tapped in the new bearings, left side first. I greased the long tube spacer to keep it from corroding. I now see how the right side bearing seats on top of that spacer. The oem bearings were a perfect fit.
Front Wheel
Size: 17x40x12mm - 2 needed
Suzuki #: 08133-62037
Common #: 6203-2RS
Seal ABS #: 09282-24004 - 1 needed
The old bearings were in good condition, so no change that I noticed.
Excellent!
And nice description of the process -- there's a specific order of operations and you can't just bang the second bearing in with a two pound hammer until it goes "tunk"; gotta stop as soon as it's seated on the spacer. A lot of folks miss that.
I keep wheel bearings and seals on hand for all my bikes and check them at every tire change. The large sprocket bearing on my Vee was feeling a little crunchy at the last tire change, so a new one went in.
1 - 4 of 4 Posts
