Have you had a look at Freeway Blaster horns WITH PICTURES! ?
I went and looked through that thread, thanks for that Gert. My installation is much simpler because I am just going to unplug the OEM horn and plug in the Freeway Blaster. On my bike, the OEM horn is directly behind the radiator on the left side of bike. In fact, it's almost touching the radiator and the mounting bracket goes straight up (to somewhere).Have you had a look at Freeway Blaster horns WITH PICTURES! ?
I hear you, Rick, and as I was looking up under the bike trying to figure this out, I was holding the new horn in different positions and calculating OEM wire length (i.e. how far can I rotate it and still have OEM connectors plug into the horn). Because I want the horn opening to face at 45 deg downward to avoid as much splash and whatever else might try to enter the opening. Now, this horn will be mounted (at OEM location) behind the radiator so that gives some protection from the elements, however much or however little.This is one of those times when fretting over the installation matters. Air horns are prone to failure when positioned so that air flows over the opening of the horn. It's usually discussed in the instructions and an improper installation voids the warranty.
I spoke to the Fiamm distributor years ago. He suggested the air horns were not really suitable for motorcycles because of the possibility of failure and recommended their magnetic horns which are almost as loud as the air horns.
Horns need to be two things. Loud and reliable. Most people are not going to know their horn has failed until they need it and it doesn't work.
Positioning the horn so that water does not enter/stay in it is important for all horns. I don't think Fiamm Blaster is an air horn though. At least the half dozen that I have bought are not.Air horns are prone to failure when positioned so that air flows over the opening of the horn.
The horn is switched via a negative wire. Hook the relay up with an inline fuse switched from the ground. I like posi taps to easily tap into the switched wire. All this sounds more complicated than it is.Oh boy. Relays. More intimidation.
I run a single freeway blaster high note under fairing just like in post #6, stock wiring + about 24" of lead powers up the single horn fine. Definitely an improvement over stock meep meep.I'm not convinced the factory wire can bring the amps to drive the horn properly.
Eastern Beaver makes horn kit that might work: EB Horn KitsI have no idea where to start when it comes to relays. I know Nicad or someone directed me to an electronics company a while back, but that confused me more. I just really had no idea hooking up a horn would be so problematic.
