1 - 20 of 22 Posts
Hi everyone,
I have a novice question today, I was wondering when it's advisable to change the fork oil? I just bought a 09 650 V-strom (8k mileage) and was wondering whether the fork oil change is more related with the age of the motorcycle or the mileage (or both)?
Thanks in advance for your replies!
There are those that will recommend a few year interval. I don't get around to it often on my bikes. i know it can get right funky after a number of years.
It's a bit of a bother but it will help the bike ride better.
On my 04 wee I've done one side when I replaced a blown seal. Changing viscosity can help with how the fork feels too depending on your weight and riding style.
Notacop is right your old oil will stink and a change will help.
Now the problem is oils aren't oils, a 10w in one brand will be different to a 10w in another brand so you have some reading ahead of you.
I used (ATF) automatic transmission fluid in my 09 Wee and I was happy with the results.
All my farm bikes also get ATF, it lasts longer than fork oil and seems to stay behind the seals better, EG: less leaks past old seals.
Reactions: Vlad1slav
If you have the skill set or a friend to with the skill set assist go for it.
It also a excellemnt time to upgrade the fork internals if you want too and have the guap to do so. Springs rated for your weigh and riding style coupled with some fork inserts (Ricor and/or Gold Valve) and matching fork oil and fork brace will greatly improve and somewhat modernize the front suspension. Be forewarned once done this will then expose how the rear shock and spring need reworked to match the front.
The forks are fairly well sealed. I find most contamination is metal from the springs rubbing on the tube walls. If water works its way past the seals that metal turns to rust and the oil goes funky. Small amounts of dirt and bug guts will work their way through and add to the soup. It is a bit of a project to do so I like to do it in the winter when I can. 8 thou is not that much mileage but 10 years is a lot of time. I would change it, if there is a bit of water in there other parts can rust. After changing, the oil will be at the correct level and weight, and your ride should improve.
Here's a fork oil comparison chart.
My Experience
When I changed/upgraded the fork springs on my ZRX, I went with 1.1 Kg springs and 15 weight oil. Massive improvement. Note: I weigh 265 lbs which is at least 275 lbs when I geared up.
I generally do it in conjunction with a front tire change. With the wheel off I'm already half way to have to having the forks in my hand, so it's the logical time to do it.
Here is a very good start to finish video (which does extend to a full rebuild). For a simple oil change just jump the bits that do not apply.
Interesting to note that many fork seals are sold with dust seals as well. I'm thinking of replacing the dust seals after cleaning out the retainer cavity and changing the fluid. Does anyone have any experience with aftermarket dust seals? All Balls?
Changed my fork oil out in my 2015 650 XT a couple of months ago and it was the color of mud and thick. May of had some water intrusion, I'm not sure. The new fluid was clear with a yellow tint. I will probably change it out every couple of years from now on. Its easy enough and cheap.
I have some Cogent dampers/intimators on the way and will use those charts to ensure I do buy a good 5wt fork oil. The only thing is that it comes in 1 litre bottles, I need 500mls for each leg, and I would like to put a little in first and pump out any old oil in the bottom.
I may use Rolex's idea in Post #3 and pump a little ATF through as I have a part bottle on the shelf. Did you ever learn the actual viscosity of ATF Rolex? 5 or 10 maybe, it is quite thin.
I changed out the fork oil on my 05 650 every year(12-13K). It was always the dirtiest stuff ever drained from anything I ever worked on. It was an accumulation of dirt, dust, bugs and water(It rains a lot in Washington) .
At 100K Rancho fork boots were installed(Greywolf always was recommending them). Fluid change at 110K. Oil looked good. Clean enough that it could have been reused(Wasn't). Checked again at 122K with the same results. Do yourself a favor and install some. 30 min. job.
I'd say you're right on the money. ATF was the spec fork oil on my old V65 Sabres and a lot of people experimenting with different oils determined ATF to be 7.5 weight.
Reactions: Spec and Brockie
Thanks. Gogent specify 5 wt for their Damper catridges so I'd better follow that, but I will definitely flush with ATF.
I had been told about 30 years ago ATF was equal to 10w fork oil and I have always worked on that theory. ???
I was told to use it because it was more stable when it got hot than fork oil. ???
I have no idea if my information is correct.
Now of course oils have changed in that 30 years but I have not kept up with the times.
To this point I have been happy with my use of ATF, if I was ever unhappy with the performance on a bike I would start to experiment.
I will ask the guys at my work if they are able to test some oils for me and see what numbers they come up with.
Reactions: slovcan and Brockie
ATF seems a good idea as the stress and heat produced by being pumped through chambers/orifices is surely similar between auto transmissions and motorcycle forks. Gogent clearly emphasise the need for 5wt oil for their units to work as designed.
Does Cogent specify a particular brand of oil? Ricor does with their cartridge emulators.
Reason being hydraulic oil is not regulated as to weight like motor oil. One manufacturer's 5wt is another's 10 for example. The chart posted by Big Boy lists oil by centistokes(sp) that is the only reliable guide to viscosity.
The reason that emulators require very light oil is to negate the damper rod ports. it's "thin" enough to flow through the holes effectively bypassing them. The cartridges will be configured (ports and shim stacks) for a specific oil normally.
Reactions: baroquenride
From their installation instructions:
"Your Cogent DDC was calibrated to use Golden Spectro Cartridge Fork Fluid 85/150 (5 wt) which is a synthetic blend suspension fluid made in the USA......"
Unfortunately that fluid does not seem to be available here so I will need to look at those charts carefully for an alternative.
Reactions: Spec
1 - 20 of 22 Posts
