Fork Extension/Longer Fork Tubes
3926 Views 7 Replies 4 Participants Last post by  Motopundit
Hi friends,
I'm looking to bias my seat a bit more towards the rear and gain some ground clearance.
Anybody running extensions or longer tubes in the front? What solution did you use to raise the front?
I'm 6'2 and will be raising the back a bit, though I'm already having some issues feeling a bit pressed against the front of the seat, my cajones are having a bad time less than an hour into my rides!
Mike
Search DR650 forks here.
Search V-strom DR650 fork swap using Google.
You will get threads like these:
Thank you, I've seen these threads; seems like the DR forks are 48mm or 1.8" longer and same OD, haven't found answers about ID. I've got racetech GVE and ideally want to keep it.
Racetech wont be back in the shop till Jan 3rd to answer questions, Im hoping they'll sell me gold tubes that will fit the strom with extra legnth. my tubes are corroding and I'm worried about my new seals getting wrecked
Side topic - Im 6’4” and feel the same. I have 1” risers and the peg relocation kit on way. I bought a used stock seat as a spare to mess with and carved some of the inner foam from the arse hump and added some to the front of the seat which made it more level in general. I haven’t ridden it yet so can’t say it worked, however it’s cheaper/easier than replacing forks.
heck yeah thank you! this will definitely allow me to keep my forks internals. much appreciated!
If you go with these, please update us. I'd be curious to know.
Did you end up ordering these?
