I think I feel safer in my head staying with motorcycle tires... But I was wondering, if there is no difference between a car tire and a motorcycle tire, why do people not put them on the front wheel?
The Super T is super the Strom hasn't come out of the garage other than people test riding it since it came home. Love love love the power, and the suspension on the ES is nice to just select what I want and go. I am having a bit of a wrist pain issue after riding for 4-5hrs not quite sure what I'm going to do with that. But as of now I don't think I could go back to any Strom now. If anything happens it'll be adding a T7 to the stable.This is the problem with text. We all read it different ways. I think the OP asked a legit question and was not condescending or ill-mannered in his presentation. Just aske a question.
I will agree that no one has said there is "no difference". From limited personal expierence I will say it not as much difference as you'd think.
As a bit of thread drift, How the Super T treating you. Likes? dislikes?
Your lean angle statement had been disproven multiple times. The contact patch of a CT is quite large at any angle. Your not taking into consideration that the sidewall rolls and the tread wraps around when the weight of the bike is applied at a lean angle. Many many videos showing how this happens, also can look at rock crawlers how the tire can wrap up and around to grab the sides of objects very similar just exacerbated in that specific example. The weight issue could be an issue. Especially as the tread hardens with age I know that the Strom is barely heavy enough to adequately use the amount of grip a CT has. As my blizzak got harder on the third season of using it I noticed more lock ups from the tire and I believe if the bike was heavier with a lower cg I could've ran that tire for another two seasons. If your like me and doing mostly commuting and putting 20k+ miles a year on a bike a CT is definitely a viable option, also a option for long distance traveling without worrying about changing tires like an Alaska run. Guys are getting 30k+ miles add up how many of those $250 tires it takes to get there and you can see why a $70 CT is enticing.I wonder about handling. I don't have any more than a layman's knowledge of tire engineering, but my gut feeling tells me that in an automotive tire, the rubber compound is inherently harder, and/ or formulated to provide optimal coefficient of friction at a weight-per-area and operating temperature that would likely not be reached installed on an MC.
Also, an automotive tire's contact patch would be severely compromised in a turn at speed; its profile is not designed to provide adequate traction at even a moderate lean angle. IMHO. they are made to be used with another tire across from each other on the same axle.
Cost is an economy of scale proposition. You can buy a 255/70R22.5 tractor-trailer tire new, not retread, for around $250USD, about what a premium MC tire costs. But, in the US, there are nearly 2 million semi tractors with 6-10+ tires each and 5.6 million trailers with 4-32+ tires each, and they all need replacing sooner or later.
How about an antique car tire size? Something like what was used on a Model A (or T) Ford? You might not like the tread pattern and I suspect the tire compound was not optimized for a modern motorcycle. Maybe even a NOS tire? (just kidding Perazzi...)Another biggie is available sizes. If I could get a car tire in 110/90-17 I certainly give it a whirl.
I'm not going to debate the pro's and con's of darksiding handling, however, it is my understanding that darksiders reduce the pressure significantly (well below what is recommended for MC tires) and on the heavier touring bikes, this probably allows some flexibility in the sidewalls and a larger contact patch than running the car tire at MC air pressures.I wonder about handling. I don't have any more than a layman's knowledge of tire engineering, but my gut feeling tells me that in an automotive tire, the rubber compound is inherently harder, and/ or formulated to provide optimal coefficient of friction at a weight-per-area and operating temperature that would likely not be reached installed on an MC.
I ran my blizzak at 32-36psi. Both of my cars are running 35psi. Haven't seen too many Darksiders running "well below" recommended pressures regularly.How about an antique car tire size? Something like what was used on a Model A (or T) Ford? You might not like the tread pattern and I suspect the tire compound was not optimized for a modern motorcycle. Maybe even a NOS tire? (just kidding Perazzi...)
Ever wonder why there are not too many MC racers using car tires? Must be a reason. Not having to make a pit stop when all the other guys are stopping for new tires should be an advantage.
Honestly I'd have no problem trying Model T tires/tire technology (if they fit) as long as I was traveling at Model T speeds.How about an antique car tire size? Something like what was used on a Model A (or T) Ford? You might not like the tread pattern and I suspect the tire compound was not optimized for a modern motorcycle. Maybe even a NOS tire? (just kidding Perazzi...)
Have you compared the handlebar angle to the DL. Maybe a new set or swapping the bars is in order to mitigate the wrist pain?The Super T is super the Strom hasn't come out of the garage other than people test riding it since it came home. Love love love the power, and the suspension on the ES is nice to just select what I want and go. I am having a bit of a wrist pain issue after riding for 4-5hrs not quite sure what I'm going to do with that. But as of now I don't think I could go back to any Strom now. If anything happens it'll be adding a T7 to the stable.
Hopefully I did read it wrong and added the sarcasm myself. Between the heading and the wording just gave me that same old feeling of anti Darkside discourse that usually happens.
Again do not assume the outside edge of the of the car tire thread is rigid. It not like rolling a rigid cube where there is a definitive edge every 90 degrees. As stated many time the CT thread flexs as the bike leans over and there is for me no feeling of "transition" from straight to turning or side to side through sweeping "S" curves. Is as fluid feeling as a rounded MC tire.I have never tried a car tire on a motorcycle, so of course I cannot comment on what it is like, but I can say this.. without any doubts whatsoever, when my motorcycle tire squares off, and I swap it to a new tire, there is a huge difference in cornering and control. The bike falls into corners with zero effort, and while it also works with squared off tires, you can really feel the difference with a new rounded tire.
Having said that, if I had a Goldwing or something heavy, that ate up motorcycle tires, I would for sure put a CT on rear, but likely not on front.
Probably because running a car tire on a motorcycle does adversely affect handling. Maybe not to a dangerous level, and maybe not too significantly for the typical use (touring and cruising bikes), but even the guys who run them will admit that they get some funky feelings from the rear wheel at times.Ever wonder why there are not too many MC racers using car tires? Must be a reason. Not having to make a pit stop when all the other guys are stopping for new tires should be an advantage.
Ask and ye shall receive...……For those who want to run a car tire, fine and good. I figure riding a motorcycle is dangerous enough without experimenting. I don't ride enough that tire costs are significant, so I'm happy to spend extra to get purpose-built tires. I don't wear off all the nibs to the very edge of the tire, but I get pretty close.
If someone on the Dark Side has a GoPro and can focus it on the contact patch during some spirited riding, would certainly answer some questions about CT's on bikes. Most especially the side of the tire in the opposite direction of the lean. Details of bike weight and tire pressure would also be helpful.
