1 - 1 of 1 Posts
Hi,
I'm trying to fit a 1626B Bagster Tank Cover and I have hit a few snags. 1st I'm not sure as to where to secure the strap nearest the handlebar without interfering with either cables or steering - at the minute it's secured just under where the tank is secured at the front, but it just doesn't look right.
The second problem are the two front most side straps (the ones with the long hooks), they look like they should hook under the tank cover, but the angle suggests it hooks under right at the angular part of the cover - trying there just doesn't work and there is no other obvious place I can find.
The third problem are the two bolt hole cuts in the cover, they are seemingly too big for the actual bolts and part of the underlying tank cover is visible and the cover looks pulled at that point.
Any pointers would be most welcome.
1 - 1 of 1 Posts
