1 - 10 of 10 Posts
If you have a owners manual it will tell you everything that should be done at the 600 mile service. No they don't check/adjust the valve clearance. I do all my own services. :twisted:
Essentially they change the oil, the oil filter and check the torque on a bunch of fastners. The only ones that were loose on my 1000 were exhaust parts. Some of them were plenty loose too.
Ride well,
Jeff
C
Labor rates for motorcycles shops are probably on a par with BMW/Mercedes dealers!
M
Just a glorified oil change, I don't think most shops check fasteners either. I check for loose parts on every bike I buy as soon as I get it home. The Strom was typical compared to the last few bikes I bought, a few loose bolts. The right side passenger peg and the belly pan/cowl.
thanx
Thanx Guys.
From the horses' mouth, the service guy said oil, and tighten all the bolts, especially the triple clamp and exaust bolts. I'm keeping my $100, and checking every thing my self. Thanx again. Doug.
Oops - just posted the same question in the Wee forum.
Up here in Canada, they are saying that a valve adjustment *IS* required and are trying to hit me for $300-350 (around $250 -275 US).
What gives?
bolts
I also found many loose bolts. It was surprising. None that were loose enough to fall out though. If you skipping the first service, check every bolt visible. I am going to check 'em once-a-year.
1 - 10 of 10 Posts
