1 - 17 of 17 Posts
OK. So I am several hours from any Suzuki dealer. I do have a Honda dealer just up the road. But quickly running up to 1000 kms and would like to change the oil. What would be my oil filter choice? NAPA is also close. And then there's Canadian tire 35 kms away.
Hondas use a different thread pitch from Suzuki. You can use a NAPA Gold 1359 from NAPA. here are other possibilities. Remember the 2 turns in the manual is only for Suzuki brand filters. Hand tight is fine for most other brands.
Bike Master 314-0025
Champion PH7016
Cycle Power 314-1919
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Hi-Flo HF138 <-- Recommended
J.C.Whitney ZX063166P
K&N 138 <-- Recommended
NAPA Gold 1359 (at UAP/NAPA) <-- Recommended
WIX 51359 (at UAP/NAPA) <-- Recommended
Parts Unlimited
Per-Form J-509
ProPart 01-0029
Purolator ML16818 <-- Recommended
STP SMO-18
Suzuki 16510-03G00-X07 or 16510-07J00 <-- Recommended
VESRAH vsf-3009
For better or worse I use the Fram 6018. Usually in stock at Canadian Tire. $9. For that price change it every oil change. 1 turn from seated for the Fram
Wera688 got over 300,000 miles on his Vee using Fram oil filters. They can't be too awful.
Yup...and that crappy Castrol oil. Perfect example of don't believe everything you read on the internet....except for this forum...all true....most of the times
In the beloved words of Clint Eastwood....Opinions are like :asshole:'s, everyone has one..........
Whooo hoooo, my 2011 wee filters actually cross over! :hurray:
The only other think that swaps over are the Barkbusters. Pretty much nothing else. :headbang:
pmk
For those who would like to use the Bales adapter for the Purolator Pure-One PL14610 filter et al, the original V-Strom adapter at Bales Technical Service Oil Filter Adaptor will fit the Vee2. The OEM stand union has the same part number as those on the Wee and Vee.
pmk
The same filter fits a GSXR750, Hayabusa and probably a whole lot more.
I haven't even priced the Suzuki filter at my dealer, how much do they usually run? I just threw a Fram on at my 600 mile change because that's the only one I could find at Walmart. It was $9. I have a C-14 Kawasaki, Honda ST1300 and a Honda NC700 and they all use the same filter, the Fram for those is like $6, they look almost alike but I run Purolators in those. $3 more for a Suzuki filter what gives. I did find a couple of ML Purolators at Pep Boys but they were $12.
Hi.
I am new here with a V-strom 1000-2014.
I realise that Oil filter KN-138
and the air filter ? to change from stock.
It appears the Vee2 is the first V-Strom with an air filter different from the others.
Hi.
Finally one more member from Portugal, beside myself. I'll be looking at new 1000 at the beginning of next year. In the meantime, I'm OK with my 2012 650.
Boas curvas !!
1 - 17 of 17 Posts
