1 - 3 of 3 Posts
The PO of my Wee traded it in with the Suzuki top case made by Soft. Somewhere along the line the left side rear "reflector" was broken off. It does not appear to be something I can purchase a replacement for. So, I think I will probably remove the other reflector and fill the depressions and paint the top. Any idea on what I could use as a filler? I had thought to use some structural epoxy, but I need something more solid that will stay where I put it.
Thanks,
Tom
Filler
I've been able to fill voids in plastic with JB Weld. Trick is to mix the two chemicals together in favor of more-thick, rather than runny, so it will stay where you put it until it solidifies. Once dry, it's hard, and can be sanded smooth and painted.
Good luck.
1 - 3 of 3 Posts
