Search for dealer mode, don't know how to for your year.
Thank you for the code list. But I'm afraid I don't understand how to use a paperclip, spare key, or get to dealer mode. Does the information show up on the motorcycle's display? Do you have a more detailed description how to get codes? I've never gone through that procedure. I'd appreciate more detail when you get the time.Backpackers reason for the spare key is because turning off the engine will cancel the FI code - so you must read it before switching off.
Do these threads help?
FI error code C65- 2017 650 Vstrom
My amber engine warning light came on while riding today. The FI error code was flashing. When I got back home I was also able to pull the FI code which showed error code “C65”. I read online that could be "Clutch lever switch issue or Idle speed malfunction". I do remember a few days ago...www.stromtrooper.com
How to clear FI code??
So my 2017 650 was showing a "FI" code after I had the tank & air box off to install OEM heated grips. I put it in dealer mode and it showed the error was from the air temp sensor in the airbox (C21). I think at some point I turned on the bike while it was still unplugged, causing the error...www.stromtrooper.com
Thank you for the prompt reply. I've got something else to do today, but I'll try to get a code to display and take the appropriate steps to correct. I'll report back when I have a result. Thanks again.All V-Stroms are similar but look to the last post in the link below for your plug. The two RH terminals need to be bridged with a piece of wire or even a paper clip. The bridge can be left in place if you wish and you will immediately while riding see the fault code on your dash when FI comes on.
Help, Fuel Injection code and I'm on the road
Oops, correct the title. "Fault Indicator". On the road finishing up a 6500 mile trip with 560 miles left to go. Bike threw a FI code with accompanying engine light. Bike still starts and runs fine, but I can't access the odo and trip meters because of the flashing code. Turning bike off...www.stromtrooper.com
Problem FI light on?
Hello from Finland! I had problem whit my bike dl-650 -05. FI light start on and code c00 after driving about 20 km on the high way speed 100 km/h. Bike has installed Bos exhaust and rapid bike fuel cotrol system. I visit to dealer and diacnostic dont show anything...all was OK. Does any...www.stromtrooper.com
