Fender Bolt size ( 2004 650)
1451 Views 6 Replies 3 Participants Last post by  Rolex
Does anyone know what size bolt is used on the back fender.
#4 in this picture.
Thanks.
It is listed to fit many more bikes on your link, when you look them up it tells you it is 6x16
Cheers.
Reactions: 1
My pleasure.
#4 in this picture.
Thanks.
It is a 6 mm and sorry do not know the exact length. If you go to a small hardware store that stocks Hillman hardware/bolts that might have this under the GM body bolt section. Look up Hillman GM body bolts 6 MM and if I remember correctly the stock number maybe ended in 48. Do not have access to my paper or my bolts/or mc right now. Maybe Dorman has the same bolt as well. Dorman is usually at auto parts store. Let me know how this works out for you-wish I could have been more accurate.
I brought in the right side intact fender bolt along with me to the local Hardware Store. They have a metric bolt sections. Found a stainless steel 6 x16 bolt a touch longer than OEM. Grabbed a couple fender washers at the right size as well. Bought 2 and replaced the current and missing bolt with the new SS bolts. No issue.
Thanks for the help everyone.
Now you know that bolt is a 6m if you ever need to know the size of another bolt you can compare with that bolt.
Bigger or smaller, longer or shorter.
Reactions: 1
