1 - 4 of 4 Posts
while out of the country i bought a new 2018 wee.
when i got back i had a chance to put a few miles on it.
unfortunately i had to go abroad again but not before stopping by happy trails in bosie to get some accessories. panniers, bash plate,crash bars and a center stand.
i have read some threads here in the install process.
my question is ...is there a sequence for these items? bashplate first? center stand? i will back in early june in a big hurry to get these mounted and log some miles.
and council will be most appreciated. cheers
I would do the center stand first. The bash-plate should be an item that is easy(ish) to put on and take off due to you needing to change the oil and do engine maintenance. And, the center stand is likely going to be a mild pain in the rear especially if you don't have anything to hold your bike up.
Reactions: Krisinmex
Depending on the skidplate, you need the crashbars installed first. I agree with centerstand first. Makes installing bars and plate easier because the bike is upright. I would also do skidplate last. Panniers can be installed whenever.
1 - 4 of 4 Posts
