Hello All,
Well I looking for a few ideas of what to look at to fix my issues outlines below.
History:
I have a 2006 650 Strom with 42K on it currently. I have owned it since the early 30K's. The guy before me was doing a lot of off road riding with it on ORV trails and decided to get rid of it to buy a dirtbike.
Problem:
Shifting from 1st -> N has always been a bit of a challenge on this bike. Some days it works great, others it is a bit of a fight. Early last year i started to run into many issues with clutch drag when the clutch was squeezed in. After trying to adjust it about 20 times i mostly eliminated that problem unless the bike gets really hot. I am a MSF RiderCoach so after doing drills in classes the clutch gets quite warm and start to drag and pull quite bad at a stop.
Last year right before i put it away it started to fall out of gear on me. I can be pulling away from a light in 1st or 2nd and as soon as i roll off it will go to N. It is also happening when I am engine braking down through the gears. As soon as i hit 2nd it will fall to N. This doesn't happen every time, but at least 2-3 times per ride. Some days it acts fine but then just at a steady speed it will fall out of 2nd.
I had had to replace a clutch before so I'm not terribly scared of that but a few friends think it may be a transmission issue.
Thanks for any innput.
History:
Problem:
