1 - 20 of 20 Posts
My front fairing off, side panels too
the tank is removed without too much ado.
air filter is cleaned and letting it dry.
when it is ready oil I'll apply
the fastners are numbered with tape that is masking
so that putting them back "should not" be too tasking.
Now that the insides of my wee are exposed.
Some wiring corrections and upgrades proposed.
"oh no" said the troopers "your circuits will blow!
The gps wired to the headlight must go"
"H4 dual headlight relay kit we advise.
heavy duty disconnect option is wise
PC-8 panel or 3 circuit solution,
have all your accessories and no retribution"
Is this complete, did I leave anything out?
if you think of something please give me a shout!
Haiku
Too naked wee sleeps
Eastern Beaver rising sun
Shoei awaiting
way too funny
my Vees just the same
alone in my shop
with just me to blame
the oil change is done
of course a filter as well
it's all sort of fun
K&N filter still damp
it's get's oiled when it's dry
either by sun or a lamp
sometime I say F....
hope that tank will fit back
those plastic rivets do suck
Are you going to check valve clearance at this time?
With all of the wonderful wording and rhyme
All you come up with is "check valve clearance this time?"
Your lack of alliteration does not match with those
Who offer advice with creativity through prose!
Sent from Motorcycle.com App
valve clearance
it very true
valve clearance is due
a good point you bring to my mind.
yet valve clearance or clutch
engine work and such
best to an expert assigned.
I can farkle with flair
in tires put air
alas not so mechanically inclined .
Plugs and valves, since it is apart anyway.:D
Not to hi-jack, but does a Wee have enough juice to run high and low beams at the same time?:D
Enough power you know
To run hi and lo
But together the heat
Might melt headlight though
In case anyone though doggerel was a canine species.....:green_lol:
I like it, though. Keep it coming.
"Would be a perfect time for a CCS100 cruise control install"
After which the right hand won't have much to do at all.
On the interstate in the state of Zen,
Pick a destination and get there when?
I know, I'se Ill-literate!:biggrinjester:
No you say then oil it when?
I should have mentioned it's a K&N
I can't speak for the K and N but the standard filter is an automotive style paper filter.
You don't oil it.
And I see what you did with the rhyme there.
1 - 20 of 20 Posts
