1 - 10 of 10 Posts
Started my 2007 Wee today to go for a ride, about 3 miles from home noticed
throttle response was not as it should be above 5000 rpm.
Drove on hoping things might improve but alas not so, as the F1 light came on.Stopped on hard sholder & did a few visual checks but saw nothing unusual.
Started up bike again no problem F1 light stayed off & everything normal.
Drove about 10 miles & F1 light came on again but throttle response was normal. Decided to call it a day & drove home, F1 light on all the time.
When home stopped the bike switched off ignition, then switched on again & noticed that fuel pump primes & switches off as normal but a chattering noise continues after the pump switches off & before I start the engine.
Engine starts as normal & idles as normal but F1 light stays on & cannot tell
whether chattering noise is still there or not as engine drowns out the sound probably.
Anybody got any ideas greatly appreciated
The chattering noise is probably a stepper motor. You need to read the error code a fault indication puts out to pinpoint the problem area. FAQ: Dealer Mode & FI Error Codes
Ok Greywolf thanks for your help
Went into dealer mode as you suggested Fault Code C28 comes up when engine is running indicating fault with STVA(Secondary Throttle valve actuator). I know thats on the throttle bodies somewhere but not being very
familiar with the setup I might leave that to the professionals unless there's something else easily checkable
Thanks again
The STVA runs off a stepper motor so that's what you are hearing. Hope the linkage is sticking or there is a bad electrical connection or something like that. As far as I can tell, the STVA is not available separately but comes with the throttle body assembly.
If it turns out that way I will have to try source throttle bodies secondhand
Would the stepper motor be interchangeable with any other suzuki models
or can the stepper motor even be replaced at all i.e. not possible to remove?
Sounds like an expensive fix otherwise, is this a rare problem??
Thanks for your advice GW you are a mine of information
I don't know about other model or even other year interchangeability. See DL650K6 c28 code for one case of fixing a C28.
Just got my bike back from my mechanic
Apparently secondary butterfly valves were sticking in one of the throttle
bodies. He had to remove shaft of offending butterfly and clean up & lube
with silicone grease. He did likewise with other throttle body.
Fortunately stepper motor & plastic cogs etc. were ok
About 5 or 6 hours work total, from what I understand not a job for the
amateur
Bike running perfectly again, happy days:hurray:
Hope this may be of help to others
That's good to hear. C28 codes usually are about a sticking mechanism.
May be totally unrelated but I had code 28 come up 4 or 5 years ago. Switched brands of gas and the code cleared after a couple tanks. I know not why but it was a cheap fix.
1 - 10 of 10 Posts
