1 - 16 of 16 Posts
DL650 K7
Hello internet,
yesterday I noticed my rear brake pads being completely worn out at 44000 km. Last time I checked at 35000 km and they were fine. The brakes were dragging a bit at that point so I cleaned the caliper and pistons and did all the sliding pin maintenance. The brakes were still slightly dragging afterwards but the rotor didn't feel hot to the touch so I left it at that. I can't tell if that has changed in the meantime.
I don't use my rear brake much and don't rest my foot on it. I recently filed down the rear brake push rod at 42000 km to lower the brake pedal (see this thread: Rear brake pedal adjustment bottoming out after foot peg...) and tested the brake pedal forcefully on several occasions.
Today I took the caliper apart and noticed wear on the piston on one side only.
Sculpture Art Wood Artifact Statue
Automotive tire Sculpture Artifact Art Statue
Automotive tire Bumper Automotive exterior Gas Auto part
pads good at 35000 km
Bottle Eyewear Audio equipment Event Fashion accessory
Automotive tire Audio equipment Font Material property Gauge
Top Piston seal bit dirty but looks ok, bottom seal seems fine too
Automotive tire Tire Motor vehicle Rim Automotive exhaust
Oooops, I wish I hadn't pushed it back in.....
Food Tableware Liquid Drinkware Beer
brake fluid from the calliper quite dark, last flush 8 month ago
Wood Gas Tints and shades Close-up Metal
Only in the photo the damage was obvious to me, just looking at it I could easily have mistaken it for some stubborn crud
Gas Auto part Wood Metal Household hardware
opposite side looks better, just some very hard to remove crud?
Couple questions:
Did the piston get stuck and could only move back on one side which caused the damage? I'm trying to understand the mechanics of it...
Could my modification to the push rod have anything to do with it?
How likely is the piston responsible for my woes?
Could I be ok using the old piston and new pads and just see if the rotor gets hot?
I'm going on a 6000km trip to Greece soon. I'd be happy if anyone could share their experience with brake and piston wear...
Thanks!
· Vendor
There is a good possibility the piston o-ring seal might leak in the future. I would replace at least the piston and seal.
As for how it got there, I don't know. But that hard plated piston did not become abraided by the O-ring. It must have been rubbing against the housing.
The brake pad wear looks relatively even. They just should have been changed earlier. It happens.
Check the housing closely before rebuilding. A used caliper might not be more than a caliper rebuild kit.
Years ago I thought I had brake drag on the rear of my Wee, I spent hours looking for a solution only to come to the conclusion that there was no problem.
Ride the bike, use the brakes and get everything hot, stop, put the bike on the stand and spin the wheel.
You will get some drag on the wheel from the chain and the brakes as the pads will always be in contact with the disc.
Ensure the disc runs true
If you think that drag is excessive from the brakes crack the bleed nipple to see if there is any pressure.
if you have pressure you have a problem, if there is no pressure you are unlikely to have a problem
I'm with Richlandrick and the piston is probably due to be replaces as its got surface area that the finish is compromised. It will only get worse as time goes on and at some point will leak. As for brake pad wear I also agree it looks normal. On my R1200GS the rear pads the piston side wears at a rate 2X faster than the non piston side. Its just the way they brakes are and how they wear.
I don't have that wear problem but I do tear the brakes down and clean them now and then. So the 2x wear one side isn't an "They all do that problem", most likely it's the slide pin has grooves in it as well OR the anti-rattle springs are in the wrong place or missing. You can buy replacement pins.
Yeah, new piston at least and it may be worth just getting a new rear caliper instead.
DL650 K7
Discussion Starter · #6 · (Edited)
Thanks all, appreciate all your feedback. @richlandrick the housing looks fine, i don't see any place it could have rubbed against. I presume dust gets in the seal, crud builds up, the coating gets ground away by the particles in the seal and then corrosion sets in and thats the damage you can see now.
I ordered a used caliper on ebay for 40 bucks including shipping (compared to 55 Euro for Piston and seals). I'm already a bit weary of the condition it might be in but it goes straight back if there is any pitting on the piston too. I'll update when it's here.
2015 Vstrom 1000
Brake lines in good shape. Have seen on vehicles, lines break down internally and hold residual pressure.
Reactions: strom_r0m
DL650 K7
Discussion Starter · #8 ·
15 year old stock lines, nothing unusal to report when I last inspected them, dunno what that says about the inside...
I'm planning on replacing them at some point but without any apparent damage I wasn't in a rush to do so. I haven't read many posts here regarding problems with old brake lines.
When I experienced brake dragging, I found my slide pin had developed a groove. OP's is visibly dry and corroded. It doesn't take much grease, you could apply it with a toothpick.
It might seem counterintuitive, but you should be using the rear brake more so that it doesn't seize up.
In 150k miles, the only rear brake work I've needed to do is change the pads, grease the contact areas, and replace the disk (after it dragged causing excessive wear).
I'll add...
Replace the dust/sealing boot(s), too. Be SURE it's seated properly. Burp the air out of it when pushing the piston in, & be sure the accordion folds are proper.
Often times a corroded piston is because that boot wasn't sealing.
DL650 K7
Discussion Starter · #11 · (Edited)
Interestingly, upon cleaning and further inspection there is actually some marginal pitting on the slide pin that I hadn't noticed. Again, magnified in the photo though.
Might have contributed to some sort of seizing up of the whole slidepin-brakepad-piston arrangement. Not sure ...turning the pin 180° when reassembling sounds like a good idea anyway.
I did grease the slide pin at ~35000 km when I cleaned and lubed all the parts following the advice here on the forum. I had mixed feelings about lubing that part though because it does get filthy in no time and the lube exacerbates it and I didn't appeal to me cleaning and lubing it all the time.
Wood Tool Household hardware Hand tool Fashion accessory
On a sidenote: I had similar pitting on both front brakes on the marked pin (not my brake in the photo). I also read descriptions of that issue here on the forum. No issues with the front brakes so far though.
Shoe Bicycle part Auto part Glove Personal protective equipment
I wonder if this is unavoidable with this type of brake (combined with an unwillingness to clean constantly) or if the brakes on the wee are extraordinarily crappy.
DL650 K7
Discussion Starter · #13 ·
That's the condition of the piston in the used brake caliper that I bought...I'm not thrilled....
I guess all pistons more or less look like this though...is it worth a try or will i send it back?
Light Product Rectangle Cosmetics Textile
Your original looks better, at least in the photos viewed from the other side of the planet. I don't know what they feel like, though.
You can get a new piston in a set with new seals from Suzuki, part number 69100-04820 but of course that may take time you don't have.
Another option if you have a motorcycle junkyard around might be to look for a used caliper from a later model bike, which would be a lot less likely to be that corroded. This caliper and piston is still in use on current model Suzukis, the DL, SV, and GSX1000/750:
Lastly, this exact same rear caliper is also in wide use on many other Japanese brand motorcycles, so that may be worth exploring.
Reactions: Gert and strom_r0m
DL650 K7
Discussion Starter · #16 · (Edited)
Can you catch your nail on the scratches?
No.
I cleaned and reassembled the newly aquired used caliper now and put it all back together, added new brake pads and bled the lines.
Since my original brakes weren't leaking and the brake pads might just have reached the end of their life I don't feel terrible about it.
The old one looks more scruffy but the single scratch in my OEM ones was actually worse.
I will go for a test ride now and tightly observe from now on for any binding or leaks. It's not a perfect solution but I don't expect catastrophic failure.
Edit: went for a ride, new brake pads feel great compared to metall on metall 🤓, rotor warm after riding, seems ok for now will see how it develops.
1 - 16 of 16 Posts
