1 - 3 of 3 Posts
There is a misplaced connection dot in the fuse box of wiring diagrams I've seen for K4 and K5 DL1000s. The K3 was okay. I've put a green dot where the connection appears in the manual. That spot should be a crossover. The connection should be where I've added a red dot. (on the left for the colorblind). The common wire feed to those fuses should be the orange wire.
Only you would be proofreading electrical schematics for Stroms GreyWolf....
The masses thank you for your dilligence :thumbup:
1 - 3 of 3 Posts
