Ok, so I am no mechanic as I am sure this question will lead you to believe.
I am trying to remove the under cowl (dl1000 K6). The pop fasteners are a PIA how I remove this without breaking them. Also, if I do end up breaking one where can I get more?
Thank you in advance to wise and powerful stromverse of mechanics.
Oh wise and powerful greywolf
Thank you!!!
I find that spraying them with a little silicone spray makes the push pin easier to move as well as removing the fastener. Helps to loosen and remove some of the built up grime.
