1 - 2 of 2 Posts
I added a relay and covered dual bus on a single fuse under the seat for Powerlet and Cigarette Lighter plugs (using Rick Hughes' outstanding shelf for the DLK & Wee.) I'll work on posting pix if there's some interest. Think I'll also add a direct cigarette plug to the battery (with a switch) for the air pump and computer . . . keeping it under the seat on a longer lead.
If you folks have some alternative ideas I'd appreciate hearing them.
Regards,
Mike
I added a cig lighter power outlet to my strom and mounted it inside the right side cable guide 8) Always hot so my GPS doesn't lose power when I stop for fuel. Everything else runs through a Blue Sea Fuse block switched to a relay that kills everything with the key 8)
1 - 2 of 2 Posts
