Providing all terminals are clean & tight, the wires are big enough to carry the load that set up should be fine.
There are parts of the system that get power 24/7 weather that is at the battery or a few inches away it should not be a issue.
quote; "Since I'm going through stators " I take it that is your problem ?
Is it a 650 or 1000 and what year model ?
What regulator are you using ?
A shunt reg can shorten the life of a stator.
It gets even worse if you reduce the electrical load by reducing the number of headlights and or going to LED globes
Is the reg getting cooled by good air flow ?
Is the battery good ? if it is on the edge replace it.
These are the first things that come to my mind.
