Serious electrical issues at the moment.
Bike dies sometimes but always restarts.
Gauge needles sweep FI light flashes.
No FI codes.
No fuses burnt.
When it dies in neautral green light will flicker and not shut off with key off until shifter is moved slightly.
Aterwards everything cycles as normal and re-starts.
When riding it will run rough farting and popping and my stainless header will turn a vivid blue.
Doesn't always die and sometimes no problem for hundreds of KMs.
Recentyl replaced flasher relay which seemed to make bike run better and heated grips magically worked again while idleing in neautral but first ride had same problems as before and heated grips stopped working again.
Now thinking problem is possibly in the main keyed ignition switch as i had lubricated it with WD40 when it got sticky.:headbang:
Now notice in manual warning about lubricating switches and think the ignititon switch is now compromised.
Any Ideas... Spent 138$ on relay from suzy stealer already
If you don't have any constuctive criticisim then go ride your bike:argue:
No FI codes.
No fuses burnt.
