This afternoon I gave the Vee a good washing. Yes I know washing jinxs vehicles but I never expected any significant problems like I have.
Before washing the bike started no problem. The battery is a Cycle Gear lifetime battery. I keep it on a Battery Tender Jr.
After washing I tried to start the bike and nothing. Zero. Nothing at all, no headlight, no fuel pump, nothing.
I pulled out the main fuse and checked with a meter, its good. I pulled the fuel injection/ignition fuse and it is good. There is no water anywhere around the battery or fuses. When I checked the battery voltage it registered 5.48volts.
So I put the battery tender back on it and after a couple of hours the voltage was back to 12+ volt. I put the meter across the terminals and switched on the ignition. The meter went from 12+ volts to 0.00 volts. When I turned off the ignition the voltage went back to 12+ volts. I checked the wiring that I could get access to without disassembling the plastic and nothing out of the ordinary.
I need the bike up and running later this week because my Jeep is going into the shop for some work at the dealer so it will be my only means of transport without renting a car.
Does anyone have any thoughts as to what gremlins might have gotten into my bike and what solution there might be for them?
Thanks for any and all advice/suggstions.
