1 - 6 of 6 Posts
Bought a ABS cutoff switch from a member with no instructions. I know it is simple but cannot fine where to connect the 2 connectors to. I see the 2 ABS fuses under seat. Are the connectors at the bottom of those and which one does it go to. This set up already has a switch with it.
A pic would be great if someone has.
Thanks.
Do a search
Grey Wolf helped me with this issue some time ago. See if you can find it by doing a search.
motor fuse, not valve fuse
its in the middle of the three things (relay on left, your loc'n in middle, undisturbed switch on right)
Ran a search but could not find anything. So the two connectors go into the top of the little fuse cube. That is what I am looking for. I did not pull the yop but I assumed it was just a fuse.
You separate a connector near the battery positive post on a small red wire from the post and the switch wire ends plug into the connector halves.
1 - 6 of 6 Posts
