1 - 13 of 13 Posts
There's more than one way to remove this sprocket. Here is my way to make it easy. Remove the cover, bend the safety washer tab away with a wide blade punch or screwdriver, and then shove a rod/or old screwdriver shaft between the rear sprocket teeth and chain as you rotate the wheel forward which will jam it. Keep it tight while you use an impact wench to remove the primary nut. You won't damage anything at this point because you are changing everything as a set anyway.
I usually use a rolled up shop rag.
I just use my hand to hold the sprocket while turning the nut with my fingers.
Jeeze, you guys are sissies!
Here, take the bong. Then try the sprocket again...
:beatnik:
Super Moderator
i put a 2x4 through the rear wheel. i use a breaker bar. no sissy air tools for me!
That is a much better way to do it, of course I still prefer a buddy to sit atop the bike with the rear brake activated.
You have a "buddy"?
Tell us all about him.
Inquiring minds want to know.
You can have the bong after you tell us. :beatnik:
I tried the 2X4 trick to, didn't work very well. Had a friend step on the rear brake (as BigB stated) works much better. The wood, for me, didn't bind in well and just jumped around when I tried to break the nut loose. I would not recommend using a metal object such as a screw driver on the back sprocket. Could mess up the teeth fairly easily. Besides, having a friend over while you perform bike maintenance gives you an excuse to drink hoppy beer and brag about your bike farkles. :biggrinjester:
Guess you didn't read the post. You are changing both sprockets and chain as a set so why be concerned about the teeth. That was the point. Once the rod/screwdriver is wedged between the teeth and chain, use an impact or whatever you want to break the nut loose.
Living the Stereotype
I usually slide a credit card in and out quickly.
I stay clean and I don't risk my lucrative hand modeling career.
1 - 13 of 13 Posts
