Here goes. V2 2014 61k
I have now put over 10k on the a new front and rear Trailmax Mission set. That in itself is pretty impressive given that much of the most recent 4.6k trip was on hard ridden twisties going to and from the eastern rally. I have run many Tourance tires but they never got close to that mileage. However they have ~8mm tread depth, the rear mission has ~10mm depth.
The front is now pretty cupped but still has significant tread left. However it has gotten annoyingly noisier.
The rear is still not at the wear indicators and probably good for another 1-2k if accepting less grip. However it obviously is now pretty squared off with most of it 10mm tread depth gone in the center and basically non at the outer edge. On this trip I never felt completely confident at larger lean angles accelerating out of corners (dry and especially wet). The rear seemed to step out just a little once you were on the outer edge and pushing a bit.
The ABS/ TC issues: With increasing wear of the rear tire my ABS now shuts down after a few miles riding. I think this is because the computer records revolution differences that are outside the tolerated range. It started doing so occasionally and shutting of the ignition would re-set it. But now, with more wear the light comes on always after just a short time into the ride, so its impractical to re-set all the time.
I had the same experience when I was running a darkside rear tire that was just a little smaller diameter than stock. That tire caused the same issues once it was worn. However I would not expect such an effect on a stock size set of tires. The TC also acts up and interferes unexpectedly when accelerating even modestly, so I had to turn it of for the last ~1k.
So my question: Is this just my bike behaving strange or is there anybody else with similar experience?
Wear Pattern of Trailmax Mission.
NOTE: I did not take pictures and measurements when I mounted them but only about 1k after. Based on wearing the rear to 2mm would result in +12k longevity. That is much better than the Tourance's I ran before that were totally bold before 8k (same bike, similar type of rides with luggage most of the time). The fronts can go longer but the cupping is a problem.
