No, it's not a Strom but wiring is wiring. I am installing a set of Baja Designs Squadron Pro driving lights on my VFRX, I procured an OEM factory unlit fog light switch from Great Britan. It has 2 wires, the illuminated switch from the Baja Designs harness has 3 wires. I am assuming the 3rd wire is for switch light power, correct? Do I just cap off the hot lead to the 3 wire switch? If not what do I do to get the 2 wire switch to trigger the relay? I am an electrical moron, unless I have a schematic in front of me I am lost, so any help would be appreciated.
You are correct, but which wire you cap off depends on if the switch is designed to switch the positive or negative leg of the circuit.
I'm an electrical engineer and often find it challenging to work on systems without a schematic.
It would help to know a few things before offering advice. (Otherwise, it would be conditional and complex.)
1. Do you have a headlight relay already installed on the bike?
2. Do you want to enable the indicator function that the 3-wire switch makes possible? (Your post suggests maybe not.)
3. Do you have, or are you willing to obtain, a (likely cheap) digital DMM with which to figure out what the 3-wire switch is?
4. Would you like (or be willing to accept) the driving lights being forced off when the headlights are off?
Thanks, everyone that replied, I got it worked out. The data or switch power wire gets capped unless I run the dimmer, then it gets spliced. Thanks.
