1 - 15 of 15 Posts
I saw somewhere that the footpegs from a DR650 are a direct bolt on for the Dl650. Of course I can't find the link now. Can anyone confirm that they work?
I can get Dr650 pegs on ebay for about $30 shipped; sure beats the price of the Touratech pegs.
The KLR 650 ones are a direct fit, and the DR ones need some drilling and bigger pins. I have the KLR pegs as seen on ebay, and they are great! I bent the spring a little, but other than that, it's a 5-10 minute job max.
http://www.advrider.com/forums/showthread.php?t=311936
I bought the EBay DR Pegs.
I also ordered the DR650 Pins, springs and clips $8.00 Australian) from a dealer.
You will need to drill the footpeg mounts.
Total time to install including drilling the footpeg mounts and the original pegs so I can put them back on in the future: About 10 minutes.
David.
Measured the stock DL650 peg pin and it is approximate 20/64" OD and the stock DR650 peg pin hole ID is approximate 26/64". Drilling out the peg mount for the larger DR650 pin is a good way to go. Took the DR650 peg & spring off of my KLR & installed on the DL650 temporarily this morning for a couple of photos:
Cool ! Thanks guys
The ones from ebay required no drilling or changing the pins. The stock DL springs will also work. Just flip them upside down and bend the ear back. I liked them alot. Very little extra vibration, and a much more stable feel while standing up. I had a minor low side on pavement and broke one. Yep folded like a cheap card table. I dunno maybe the stocker would have done the same. Oh, well if I get them again at least I have a spare now. Worth the $30 IMHO
Will the KLR pegs fit a 1000 ???.
1985 Kawasaki hardtail chopper
1990 Honda CR125 woods weapon
1992 Suzuki 750 Katana
2001 Yamaha TTR 225
2004 Honda CR125
2007 Vstrom 1000
“ I REFUSE TO TIPTOE THRU LIFE ONLY TO ARRIVE AT DEATH SAFELY “
I have the Ebay pegs, I think the KLR ones, anyway, direct no drill replacement.
It makes shifting a little harder, even after adjusting the shift peg. But they don't feel slippery after having my feet down in mud.
Life is all about trade-offs. Chose yours.
Evolution Footpegs
I had a set of Fastway Evolution footpegs on my 950 KTM Adv, ordered a new set of pins for them $17.00 and put them on my DL650. Work great, my feet stay where I put them. :cool:
Discussion Starter #13 (Edited)
Has anyone thought about sleeving the DR pegs to make up the gap, rather than drilling the peg mounts on the bike?
That's what I did. I found some 'drill sleeve's at mcmaster.com, but they only sell by the box. So I took a tee nut and drilled out the threads. It's been working well for nearly a year now.
Surely you all aren't talking about STOCK KLR pegs are you? Those things suck (I know, I ride a KLR).
Anything is better than the stock "rubber nubs". So, is it dr or klr pegs? From what I read it sounds like the klr are a direct replacement.
1 - 15 of 15 Posts
