Don't do like I did, and if you do, here's how to fix it. AKA, what happens if you bypass the clutch safety switch on some years of V-Stroms
2747 Views 10 Replies 8 Participants Last post by  MeefZah
I come out from work and my trusty 2011 650 Strom won't start. And to be more specific, it won't even turn over. And it's not the battery because I have a nice voltmeter so I can check the voltage with the bike on or off. A nice healthy 12.7 volts before I turn anything on, and more importantly.....the voltage doesn't drop at all when I hit the start button. If the battery was the culprit, we would see it drop by a mile when I hit the starter button. And it would probably make some kind of noise, either a clicking solenoid or a sad slow ineffective attempt from the starter.
Ok, so it's not the battery. The easiest thing to check is if it's the clutch safety switch, and since that is often the culprit I start there. I wiggle the connector off and jamb a little jumper wire in there to bypass the switch itself. BINGO, it starts with enthusiasm and off I go. Problem solved right? Fix or replace the switch at my convenience and be careful not to start the bike in gear. Bob's your uncle.
Not so fast....
Not immediately, but by the time I get home the bike dies at idle. Hmmmmm, what are the chances that the new problem is related to the first problem? 100% as it turns out. Some thought worked its way out of my deep subconsious that some years/models of strom, the ECU monitors the clutch switch, and if it thinks you have bypassed the safety switch, it will fiddle with the engine's ability to idle.
Fine, I'll just roll right into fixing or replacing the switch. I thought about doing the quick and dirty cheater method and blow out the debris from the switch with compressed air and follow that with some CRC electrical contact spray cleaner on the switch and connector. I chose to do it the better way, the right way. That turned out to be a mistake.
Once home, I took the barkbuster off to gain access to the clutch and switch mechanism. Loosened it and spun it 90* to get good access to the switch. It's held on by a single tiny JIS screw. Being the thoughtful and prepared japanese motorcycle owner, I whipped out my small JIS screwdriver and attempted to remove the screw. I pushed very hard, I pushed very straight in an effort to not strip that teeny teeny screw head.....which worked. I did not strip the screw head, I twisted the pesky little bugger right off flush with the clutch/mirror bracket.
FINE! I will drill out the screw and remove it and replace it with a better one. Oh, what is that I see around the twisted off shank of the screw? Yes, that's blue loctite or something like it. That baby is not going to want to come out with a little drilling and a teeny tiny little screw extractor.
FINE! I will use ALL the tricks. The total diameter of the screw is 0.108". Sorry for switching to ugly imperial. So, in round figures, I need a drill bit that will remove about 90% of the core of the screw, but not damage the female threads in that precious aluminum part. In my experience, if you pick a drill that's about 75-80% of the full diameter (threads and all) that's about right for this kind of repair. So I found a drill of about 0.080", made a deep punch mark with an automatic centerpunch right in the middle of the shank. Then carefully drilled a hole all the way through and right out of the aluminum bracket on the other side. There's no real harm in doing this, and it give you more access to squirt your favorite penetrating oil in there.
Here's the secret sauce. To kill that locktight, we need some heat. But I don't want to put a torch on the clutch lever bracket since it still has everything else attached to it. Find a piece of steel wire or a drill bit that's a good fit. Heat that steel red hot and jamb it in the hole you just drilled. Baptize the area with your favorite penetrating oil. Heat the steel up red hot again and jamb it in there. Do that 6 or 8 times and the locktite is now toast.
I very gently pounded my teeny tiniest stud extractor in the teeny little hole very gently. Then I started twisting gently but firmly while praying to all the motorcycle and broken stud gods and POP, the sweet sweet sound of that tiny screw coming loose.
As it turns out, the switch was just dirty, so the compressed air and contact cleaner worked a charm and it fixed everything. If you end up in this position, try that first.
Anybody know what years and models that the ECU monitors your clutch switch and kills your idle???
See less See more
  • Haha
  • Wow
Reactions: 5
1 - 11 of 11 Posts
Great write-up. To answer your closing question, at least partly, I have an '04 Wee and have jumpered the clutch switch many miles ago. No problem at all. I just got tired of that little connector working loose every time I parked with the bars turned left.
Reactions: 2
After 2007 is when you can't permanently bypass the clutch switch.
Reactions: 3
Only comments:
First is that those switches are probably a standard industrial component.
Second is that provided you swap in the whole thing (including the perch), it has a switch and fits 7/8 bars good odds it'll work.
Reactions: 2
GREAT! write-up.
As I was reading this, I had decided that I was just going to by-pass the clutch safety switch now before I have this problem......then I read Rolex's reply.......crap!, so much for that!
Guess I will try to remember to clean the switch often.
Reactions: 1
Thank you all for this info. What a nightmare, but you persevered. I find it beyond lame to embed this kind of firmware into the computer. What came to mind is an ECU flash to get rid of this nonsense. But I guess there is nothing available. I looked up the Power Commander and it said 'reverts to stock tune' when the box is removed, so it fools the stock ECU, but can't program it.
Edit
After reading another thread I searched on ECU flashes and they are out there, but none mention tweaking 'features'. I didn't look at them all, but maybe a custom flash would eliminate the problem completely and forever. I sent an email to P3 to see if they can do it.
Reactions: 1
I would not mind at all if they included some code that alerted me that my clutch lockout switch is on the fritz.
NOT cool to kill the idle circuit. That could be dangerous. I am interested in their response. I suppose the folks that make these custom tunes could get into legal hot water by bypassing a safety feature, and then somebody manages to injure themselves pretty badly because they didn't have that safety feature.
In a pinch you could wire in a momentary switch and mount on one of the clutch perch screws. Then you'd just need to hold that switch to start, it would be open normally.
A significant downside would be that if you accidentally stall and need to get going quick, it could trip you up.
If you wanted to get really fancy, you could wire a relay into that circuit that only closes when the oil pressure sensor is indicating low (i.e. engine is off). Of course that would be a failure point in itself.
I'm glad I have an '06 (with a clutch safety switch bypassed 2,000 miles from home)
It's all about saving fuel and passing emissions tests.
The switch on my 2014 1000 has very open contacts and is very easy to clean, my guess is the later switch would fit the earlier bikes or you could wire in a momentary switch to use as a backup.
If there is no warnings on the dash & the headlight goes off and on when the start button is pushed the clutch switch is the first place to look.
Suzuki are not the only ones doing it.
I avoid bike shops but when I was getting a recall fixed on my Strom I overheard a conversation between the head mechanics, they were having on going stalling problems with a Kawasaki, I suggested the clutch switch could be the issue, they were desperate so followed my advice, a new switch fixed their problem and they learnt something.
Reactions: 1
No reply from P3. I'll try another shop, but I'm getting a bad feeling about this. Probably not worth doing for profit.
Not so fast....
2007 and up
I had a 2007 that was stalling a lot since new, and after many warranty trips and a thread on here (in 2007) I learned that the switch bypass I had installed at like 50 miles was the culprit.
If you need to jump the switch just do it temporarily with a bit of wire and then remove the jumper.
1 - 11 of 11 Posts
