P
Discussion Starter #2
It may work, but I have no clue why either of my Suzukis would need an "electronic timing retard eliminator". Only think I can think of is a possible performance boost from running higher octane fuel. But both of them run fine on 87 octane gas - and I'm happy with that.
M
Keep in mind that the European 'Stroms are slightly different in respect to the whole timing retard issue. From what I understand that particular TRE won't work properly with U.S. spec 'Stroms. My info is based on a manufacturer that produces both models. Might do a bot more research before spending your money.
C
I'd never even consider a part like that without documented proof, and strong recommendations from this forum and the other one. I figured somebody would have given it a shot.
There are discussion threads on this in the other forum that say this TRED does not do what it says.
Bob
TRE ?
I have to admit that I don't have one. I based my comment on other info about a TRE for suzuki's from Ivan's, who is reputable.
I spoke without direct knowledge. Sorry.
My questions would be, how often do you run into the rev limiter ?
Not something that is a problem IMHO.
