1 - 15 of 15 Posts
I've seen a number of (OK, two) types of engine guards for the bike, but is there a place to securely mount a set of frame sliders? I ask because I want to figure out if there's a way to run them with the lower (aftermarket) fairing in place, and I've heard it can be a problem.
-T
Discussion Starter #2
Clarification
Let me clarify. I'm sure there's points on the frame that you could mount sliders too, what I'm looking for is information on hard-points under the lower fairing where you could mount the sliders to protect the expensive lower plastics.
-T
Clever Title
http://www.motovationusa.com/Vstrom.html
http://www.spieglerusa.com/cfm/FrameSliders.cfm
http://www.twistedthrottle.com/trade/productview/2013/203/
http://www.rg-racing.com//showproducts/Crash_Protectors/Suzuki_Crash_Protectors/DL650_V_Strom_Crash_Protectors.aspx
They're out there. I don't have any experience with them. Looks like the SW Motech crashbar bolts to the same bolt as the slider, but maybe they could both attach there OK. The Hepco & Becker guards don't use that bolt. The Givi guards look like they don't use that bolt hole, but might obstruct the sliders.
Thanks, but I'm not looking to run both frame sliders and crash bars, I'm looking for sliders that will work under the aftermarket lower fairing (no crash bars).
Thanks for the links.
-T:)
frame sliders are designed to protect frame, not faring lowers
Yeah, thanks for the tip.:rolleyes: They do however protect the lowers (to a certain degree) by keeping them off the ground when the bike falls over.
"If the shoe fits" as they say.:p
-BT
Crash protectors
R & G crash protectors ( cotton reels ) are available here in the UK and they do a very neat looking set for the DL650 where they come with a seperate aluminium cradle which they then mount off . I saw them on a 650 in a local dealership. The only problem for me was the cost PDS stlng 125 (approx us dllrs 250 !! ) I know its a small cost compared to the likely benefits but its finding the cash and convincing the wife thats the problem.
I ran a set of Motosliders on my SV650 that worked out great... They mount up like the Motivation USA sliders, replacing the main engine mount bolt, but these are a little less expensive.
http://www.motosliders.com/suzuki.html
Unfortunately, they only seem to have pics of them mounted on SV's.
I run the Motovation USA frame and swingarm sliders. I love 'em, very nice. They mount on the main long bolt through the engine and frame, they give you a new bolt as part of the kit.
So, if you were to drop the bike what would happen? Do the sliders keep the handlebars from hitting the ground? What would the damage be? Does it matter how much the handlebars are turned?
I like the slider idea, but I'd like to know how much protection they offer vs crash guards.
Crazy Old Guy
-T:)
I think the answer to your question is no, I run sliders on the top engine through bolt but you would have to drill the lower fairing to run them. I think it would be the same for the other mounting points as well. Some that are offset might work, but it looks like they would hit the fairing.
Personally, I'm, leery of frame sliders. I know of a lot of guys that had bolts break and frame damage on their Yamaha FZ-6 (my previous bike) when the bike went down. I like the frame slider idea but the length of slider required to protect the bike just gives so much leverage to the mounting point. I think the crash bars (or engine guards) are a much wiser method of protecting your bike in a fall. IMHO
You may find that the fairing is designed such that drilling it to accept sliders will considerably weaken it in the mounting area.
1 - 15 of 15 Posts
