Does someone have sketch to create a skid plate ?
2.3K views 4 replies 5 participants last post by  notacop
#1 ·
Hello everyone
I want to build a skid plate and I can not find sketches/drawings to create one.
Does anyone have plans or dimensions?
t/you
rafael
#2 ·
I have looked into doing the same thing. I have built many skid plates for my dirt bikes. From what I have gathered, building the plate for our bikes is not so difficult, but there is a bracket that has a 90 degree bend, and a funky off-set, that is required to bolt the rear of the plate up against the engine. That bracket appears to be the toughest part of the whole job.
You could use a piece of cardboard to cut a template for the plate itself.
#4 ·
Do a google search on "DIY No Weld Belly Pan", Honest Bob put it up awhile back, and I used it. Really came out nice. Mine was for a 011, so don't know if that will be a issue for you.
I used it for a guide to make one for my 2012.
Best thing is to make one out of cardboard or poster paper and get the size/shape you want, then trasfer to metal and make it.
#5 ·
Buying one from Weld86 was cheaper than buying a sheet metal break to handle some 1/8 inch diamond plate. I've got sheets of alunimum in the garage but bending it up is a problem. Good luck. I'd like to see how it turns out.
Necessity is the cause for a lot of swearing!:mrgreen:
