I've got a curious thought. I ride with +2 on the rear sprocket and the last time I changed my chain, I added an extra link to give me more room for adjustments. Does that affect anything or is performance based strictly on the gears themselves?
You actually added 2 links. None of that makes any difference. It's the bigger rear sprocket that makes a difference, not the length of the chain. As long as the chain has the proper free play, it doesn't matter how many links it has.
Sprocket and gear size affect performance (speed/torque)... The length of the chain will only effect your wheel base... Wheel base distance has it's own set of characteristics... such as wheelie abliity vs hwy stability, etc...
Theoretically: a larger sprocket will have less "stress" on a chain.......i.e. longer chain life. You will never see any difference in the real world, but on paper, the chain is happier........!!!!!!
Thanks! That's how I though it worked, but it never hurts to ask.
Sometimes racers searching for that last .0000001% of handling prowess will add or subtract chain links in order to shorten or lengthen wheelbase a wee bit.
It makes no conceivable difference in the real world, of course.
Having done a bit of race wrenching, I can tell you the placebo effect is real...
Chain Length Effect
Ditto Bwringer, especially with the DLs being on the long side, you'd have to take off 2" or more to begin to notice a difference in turns...
