1 - 20 of 35 Posts
The regular maintenance schedule calls for replacing various hoses (coolant, fuel, brake) at certain times, regardless of how healthy they look. I'm sure mine are original, so 11 years old. I can't see any evidence of cracking or hardening.
Does anyone have any particular insights on this?
If you're tempted to answer with an insult about how stupid I am for not blindly believing the maintenance schedule, please refrain. We've all heard that before.
I'm more concerned about replacing the various fluids that run through these hoses. The manual is very conservative regarding the replacement of clutch and brake lines. If they only supply lines that last 4 years... wow. Radiator hoses can look OK, but if you pinch them and they collapse like wet macaroni or have swelled to 1.5 times original diameter, then I would change them. Otherwise go ride.
I have to add that the short fuel line between throttle bodies is where you should be proactive. That hose can ruin your day if it starts to leak. It is a known problem.
This is actually an interesting question. If you bought and all inclusive extended maintenance and/or warrant on a bike would the dealer replace the hoses and brake lines at manufacturer suggested intervals or find a reason not too?
Interesting. I noticed the hoses on the 04 I got still had what looked like release agent dust on the hoses. The bike was a few years old when I got it. I don't think I've looked at the hoses since except for a small leak from the lower radiator hose on the left side and I tightened up hose clamp and called it good.
I've seen bulging brake lines but that was on a 50 year old car.
Super Moderator
All hoses on my 97 Honda Valkyrie are original, nothing is cracking or leaking as of yet. :)
I've been riding since '83, and I confess that I've never replaced a brake line or radiator hose, in spite of what the manual says. I do follow the manual for things like flushing the radiator, or changing brake fluid, but I think they recommend replacing the brake lines every two or four years, and I don't see the point unless there's some visual evidence that a problem is brewing. My Harley was ten years old when I sold it, and it still had the original brake lines, and they were fine. Then again, I'm a maintenance heretic, because I don't replace valve stems every time I change a tire and I re-use crush washers on sump drain plugs. And, heresy of heresies, I use Rotella motor oil.
Big B, have you had to replace any of the o-rings on the fuel distribution tees between the carbs? That was the last thing I had to do on my 02 Valk before I sold it a few years ago. Started it up in the spring, puttered around in the barn while the Valk warmed up, suddenly had gas everywhere!! The fuel was draining into the front cam belt area, and being squirted/thrown out every possible opening. If it had ignited, I would've had no way to get to a door. The pool of gas on the floor was huge. Still gives me chills thinking about it!!
I have recently been forced to change the brake hoses on my 1988 RT BMW, one would no longer pass fluid through it.
From the outside it looked fine.
Changed the hoses on my 650 @130,000k's as a precaution. MOST of them were O.K. if a bit limp past the clamps, a couple of the small ones not so O.K.
Consider what the downside might be. If a brake hose fails unexpectedly, you don't stop and the consequences might be very serious (and expensive). If the vent hose on your gas tank fails, it will be far less serious. Hose life is dependent on a lot of variables, and some bikes will have sterling hoses at age 20 and others may start to lose suppleness at half that age.
What makes me comfortable might not be your cup of tea. I like to have confidence that my bike will go the distance I need it to, and tend to do major service before long trips and be proactive in changing wear items BEFORE they fail and leave me stranded on the road. i used to tell my customers that they could change ageing appliances on their schedule or on the machine's schedule, and that the latter was rarely convenient and often a real pita. Things break when stressed, and a long trip stresses your bike more than a short daily ride.
The manufacturer sets intervals based on Average life span of said parts. Bikes that sit outside all the time could
have rubber parts that degrade more frequently than bikes that are garage kept unless being ridden.
The brake and radiator fluid is many times left until too late. Which causes chemical breakdown of the rubber hoses from
the inside . For which we can't see. So following a regular schedule to flush the fluids will allow the hoses to be used for
a longer duration. But why do so ? If it was my bike, I would replace all the radiator hoses when I flushed and changed
the fluid. As stated ^^^^ all it takes is a bad one of these to start spewing it's contents on the leg of your jeans or even worse
an un noticed temp gauge showing all the bars to the top while riding in a remote location. To protect your investment it pays to be
proactive. Not waiting for something to go wrong - catch it before it goes wrong. like in the garage where all the tools are.
You can work in the A/C and watch football at the same time. (at least I can ) Does'nt even seem like work then .
The other side of this coin is : plan for it! Purchase the hoses and the brake fluid ,radiator fluid a month or 2 before
you plan to do the work. It's far better to have a plan ahead of time versus broke down and on the cell phone.
Vendor
My 45 year old Kawasaki H1 had the original brake lines on it when I test rode it. I'm going to get new ones. It may have have had the original brake fluid as well. However, that brake fluid was orange with a high level of particulate in it.
Changing brake lines as routine maintenance every four years is just silly. How many 17 year old V-Stroms are out there with the original brake lines? Probably most of them. Change the fluid every year or two and everything about your brakes except the pads will last longer.
Super Moderator
Not yet, so far everything is still working as intended, I believe the 97's were the best overall year for the Valks IMHO.
Changing brake hoses every 4 years with OEM versions may be a bit much, but the first interval you might want to upgrade
to better overall performance parts including braided SS brake lines. I save a little $$ each month toward what I want to upgrade
and this is on my list.
And if you think about it all the radiator hoses are not just carrying fluid , it's fluid under pressure, hot -during cold climate,
and hot climate with cool down in between rides. So each time that cycle happens those hoses stretch under pressure and retract
when cool. And then add the chemical component to all this and the cooling system becomes more critical.
an un noticed temp gauge showing all the bars to the top while riding in a remote location. .
Dumping the fluid under the rear wheel is another concern and if you dump the fluid quick enough you may not see a temperature rise.
if there is no fluid to heat the sender you can't get a rise.
with radiator hoses I think you will know when its time to change them, a good look and a good feel/squeeze will tell you a lot.
they start to bulge towards the ends.
if your sensible you can go way past the recommended time frame.
corrosion of the metal under the hoses at the clamps can be a bigger problem than the hoses themselves but that only results in a slow leak.
I love this forum; it makes me feel like a real rebel. Not changing brake hoses on schedule, reusing crush washers and valve stems, Rotella oil, not wearing Aerostitch...I feel like the Russell Brand of old guy motorcycling.
Oh I’m way Rebel, haven’t even checked valves and I’m close too 60k.
Ride it till it blows up
Mike
Sent from my iPad using Tapatalk Pro
My 04 still has the original hoses. They are nice and pliable with no cracking. Could change at any time though. Just keep an eye on em! They will fine till they are not! Yah 4 years for brake lines is ridiculous! I changed mine awhile back to braided. Im sure those will be the last ones on that bike anyway... Now fluid changes thats another story. I change my brake fluid every 4 years regardless of how it looks. Oil I change every 4K miles or so and always before storing in the winter! Just my 2c!
1 - 20 of 35 Posts
