Hi all,
I got my Wee3 about a year ago and after looking around for luggage options that could be both useful & durable but also as cheap as possible. (That may sound bad, but having to pay ~9400EUR in Greece for a 2017 650XT forces you to cut as much as you can on accessories). I chose the Givi/Kappa option as I had a K48 top box in great condition that I would like to carry over and was considering either a set o Givi E41 (which I could borrow/buy from a friend) or go for a set of aluminium K-Ventures 37L/Dolomiti 36L in the future.
I looked around and accessorimotostore in Italy was offering a good price + free shipping for SRA3112 and PL3112. Due to production/stock shortage, the SRA3112 arrived first. Installation was pretty straightforward and took me less than an hour (preparing coffee, trial fitting, applying loctite and final fitting). The K48 top box was put on and I had a 300mile trip with no issues whatsoever.
10 days later I received the PL3112 rack. Fitting it for the 1st time took almost 3hrs, as I measured each bolt, spacer etc in order to be sure, trial fitted, removed, trial fitted once more and removed and performing the final fitting. At that moment I noticed that the lower of the 2 bolts that go through the left passenger footpeg required a great amount of force (well, at least greater than all the other bolts which for the most part I just screwed in bare-handed). After taking the bike for a ride, I noticed some vibrations coming from the rear part at around 4K-5K RPM. I called and friend and he helped me refit the rack the next day (completely remove and refit). The result was the same. As I had not completed the break-in, I was not sure was the behavior would be over 5K, but surely the vibrations were alarming.
Having planned a trip to Italy which was to begin about 2 weeks after that, I left the rack alone and spent most of the time on the preparations. The Givi E41 pair locked up fine on the rack, and I think I noticed less vibrations on the same RPM levels when the bike was loaded.
Last week, after reading a few threads on bad quality bolts/screws on Givi, I decided to go to my local shop and get a whole new set of high quality galvanized bolts. I removed the rack, cleaned the threading and trial-fitted all the bolts to be sure that they are right. I re-attached the rack but I had the same "resistance" from the lower bolt of the left passenger footpeg. I am (almost) convinced that the tolerance on the Givi rack on this specific part is not correct and this could cause the transfer of vibrations from the engine > footpeg > rack > rear part. Also, now that I can push my engine a bit higher, I have spent some 5-6hrs of riding during the weekend and have narrowed down the RPM range to 4750-5500K. I think that that vibrations are higher at this range.
I can see that a lot of owners have opted for the PL3112 rack. Did you face any issue with tolerances? Are you also getting vibrations on the rear part (felt in rear part of the saddle) after installing the PL3112?
Also, does anyone have experience with Givi RMA? (I saw that they replaced ScottKY's rack, but not sure if this was Motostorm initiative, or Givi)
Thanks for your time!
