1 - 4 of 4 Posts
Hey guys, hoping someone can shine some light on wether or not I can do a straight swap with my 3 spoke cast wheels for some spoked ones? My bike is a 2016 Dl650 & I am looking at replacing the 3 spokes with a pair of spoked tubeless wheels off a 2018 Dl650 XT, I am guessing the spacing will be the same as the fork & swing arm & brakes 'seem' identical, however I read about speed sensor placement been different between cast & spoked? Any info muchly appreciated! :smile2:
your problem is not going to be fitment and the tone rings are for abs only not speed sensor. the speed sensor is on the front sprocket.
the [problem your going to have is finding the spokers. very pricey and those that have them tend to keep tight hold on them. if your lucky enough to find a set the question is can you afford to buy them. There is an aftermarket manufacturer but a set starts somewhere close to 2k US.
Just thought I would answer my original question & confirm that the new DL650XT wheels will fit on 2012-16 650 'Stroms, bolt straight on & the sprocket carrier can be swapped between the cast & spoked wheels also which is handy. Oh & they look SWEET! Cheers
1 - 4 of 4 Posts
